We suffered a rather extensive power cut yesterday, checked the router once if had powered back up a few hours later and I have an upstream noise margin of 5.1db.
Seems like an odd figure as I know the downstream can drop below 6db but I've never known the upstream to do that.
unless it causes you a problem then I would not bother about it and it is giving you a bit more up speed than your attainable
