Davrose
Message 1 of 34
Low speed after line repair
Hello
I hope someone can help. I recently had a line fault which left me with no dial tone and my broadband download speed dropped to 0.74mb. My line was repaired on thursday but my broadband speed has remained at 0.74mb.
I have checked the adsl details which are shown below. I prevoiusly had an average download speed of 2.4mb to 2.8mb.
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 14:14:31
Downstream: 3.563 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 5.8 dB / 19.0 dB
Line attenuation (Down/Up): 52.3 dB / 31.5 dB
Output power (Down/Up): 19.3 dBm / 11.9 dBm
FEC Events (Down/Up): 354997 / 91
CRC Events (Down/Up): 15131 / 49
 Can anyone tell me what I should do.
33 REPLIES 33
ray_dorset
Distinguished Guru
Message 2 of 34
Re: Low speed after line repair
If not, I'll try again 🙂
imjolly
Message 3 of 34
I moved your post to the correct board
can you run btspeedtester and when first test completes then run diagnostic test and post results
btspeedtester
Davrose
Message 4 of 34
Thanks for the quick reply
Speed test results were download 0.67Mbps upload 0.35 ping 40.25
Diagnostics
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download  Speed
 0.67 Mbps
0 Mbps1 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.67 Mbps
 For your connection, the acceptable range of speeds is 0.2 Mbps-1 Mbps.
 Additional Information:
 Your DSL Connection Rate :3.65 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 0.75 Mbps
imjolly
Message 5 of 34
The problem is your low profile of 0.75mb which eas probably the result of a low connection speed when you were having problems. If you stay connected 24/7 for 3/5 days maybe sooner and your profile will automatically correct itself based on your current connection speed.  Your download speed will then increase
Davrose
Message 6 of 34
Thanks for your information I will keep my fingers croosed and hope it does. It has already been at this speed for two days so I hope it will adjust soon.
imjolly
Message 7 of 34
Your connection time is only 14 hrs not 2 days. It is time connected to internet not just time router powered up
Davrose
Message 8 of 34
Ok thanks I did not know that. Anyway things have improved greatly as you can see below. This is connected by wi-fi with other devices connected as well. How does the range  0.6 Mbps-7.15 Mbps become dsl connection rate 3.78 Mbps is it to do with distance from the exchange.
FAQ
 Download  Speed
 2.92 Mbps
0 Mbps7.15 Mbps
 Download speedachieved during the test was - 2.92 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Your DSL Connection Rate :3.78 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 3 Mbps
imjolly
Message 9 of 34
your profile has reset and is now correct for your connection speed
the 0.6 - 7.15 is just showng the acceptable limits for your connection and you are about middle
Davrose
Message 10 of 34
Hello again
I am sorry to say that my broadband speed has been gradually dropping since my last post when I thought my problem was solved. My line profile has dropped from 3Mbps down to 2Mbps and my download speed has has dropped correspondingly to 1.97Mbps. What can be done about this and why is it happening as my connection has been very stable. I can no longer stream video satisfactorily as I could before.
David
FAQ
 Download  Speed
 1.91 Mbps
0 Mbps2 Mbps
 Download speedachieved during the test was - 1.91 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Your DSL Connection Rate :2.66 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2 Mbps
