Message 21 of 34
Re: Low speed after line repair
Thanks for the information. when you say maintain connection for 3 days do you mean, keep my computer on and connected to the internet for three days or do not reset or disconnect the hub.
Message 22 of 34
Just do not disconnect the router from the internet - you can turn your pc off
Message 23 of 34
Ok thanks I will try that and see what the results are ,I would certainly like a connection speed of 4.3Mbps.
Message 24 of 34
I have just checked my line status again and it says I have only been connected for 0 days, 01:09:05. Could you tell me what is happening please as I am not aware of any disconnection.
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 01:09:05
Downstream:2.219 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):15.0 dB / 20.0 dB
Line attenuation (Down/Up):52.3 dB / 31.5 dB
Output power (Down/Up):18.2 dBm / 11.9 dBm
FEC Events (Down/Up):2289 / 1
CRC Events (Down/Up):184 / 5
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):239 / 0
Error Seconds (Local/Remote):97 / 1
Message 25 of 34
Your connection has dropped again and reconnected with a higher noise margin and lower connection speed. Is quiet line test still ok - no crackle or hiss
if your fonnection continues to drop then I would try in the test socket with a new filter just in cae there is a problem with your SSFP
do you use a telephone extension cable to connect your router to you filter in the master socket?
Message 26 of 34
I do not use an extension cable my router goes direct to filter. I will try the other sugestions tomorrow.
Message 27 of 34
Ok post back any time there is always someone around to help
Message 28 of 34
Hello
Quiet line test seems ok so I connected through a new filter direct to the socket with the face plate off and got the same results below. Still high noise levels so what is the next step please. I had to disconnect to do this hence the low connection time.
ADSL Line Status
Connection time:0 days, 00:07:09
Downstream:2.125 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):15.4 dB / 19.0 dB
Line attenuation (Down/Up):52.6 dB / 31.5 dB
Output power (Down/Up):18.1 dBm / 11.9 dBm
FEC Events (Down/Up):6820 / 5
CRC Events (Down/Up):353 / 4
HEC Events (Down/Up):1322 / 1
Error Seconds (Local/Remote):328 / 50
Message 29 of 34
then I would leave it in test socket if you can until you get 3+ days connection time then repost the adsl stats and mods will help by getting noise margin reset to 6db which will increase your conenction speed - but 3+ days connection time first
Message 30 of 34
Ok I will try that but I doubt if it will stay connected for that long as it has not so far.
