DJ_ultragamer
Message 1 of 6
Low speeds and unable to connect
We have got a new bt home hub 5 and it had the usual early hiccups but for the past 2 days i have had some really annoying problems, my pc connects to the wifi fine but i cant make any web searches, all my internet apps don't work and so on. My mobile devices connect but get a very low mb/s. This is a big difference to our usual 56mb/s. I have done basic checks like internet troubleshoot and reseting the router, i also checked for area problems and it said there was one but it was sorted, if anyone has any ideas of what to try let me know
5 REPLIES 5
pippincp
Message 2 of 6
Re: Low speeds and unable to connect
Is it possible for you to test a wired connection?
DJ_ultragamer
Message 3 of 6
I have a connection booster in my room which connects to pc via ethernet net but i will try it directly from the router now
DJ_ultragamer
Message 4 of 6
Yes connected directly to the router i get the normal speeds, it has worked in my room before so i dont know what the problem is
ray_dorset
Distinguished Guru
Message 5 of 6
Obviously, the problem is with the connection booster. What is it?
If not, I'll try again 🙂
DJ_ultragamer
Message 6 of 6
lly not sure what the problem was but now its working, oh well
