Message 21 of 42
Re: Lower than guaranteed speed issues
Sorry Keith but for some reason I thought you were a modSmiley Surprised
OK I am really not about to forget about it as the engineer said it was flakey and may become unstable again - - which it has and he also mentioned the router could be the culprit too.
I have re-opened my original complaint with bt customer service but if there is a MOD reading any of this it would be appreciated if they would consider assisting if need be.
Thank you.
Message 22 of 42
Thank you.
No, I am a CL (Community Leader), its a sort of sub moderation role, but myself, and the other CLs, do keep in contact with the moderators.
I will raise your issue with a moderator, it could be home hub issue, as the HH6 does not have the best record of reliability, and some peple are now using alternative routers.
Or it could just be a hight resistance fault.
Your speed is above the handback speed, so I am not sure whether Openreach are going to be interested.
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Moderator
Moderator
Message 23 of 42
Hi @SRT,
I'll be able to take a look at your connection and run a few checks on your line. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Moderator
Moderator
Message 24 of 42
Thanks for taking my call this morning @SRT. As discussed, can you please run the speed test including the further diagnostics and I'll pick up again on Friday.
Cheers
David
Moderator
Moderator
Message 25 of 42
I've picked up your last test results @SRT. I'll be in touch once I have any updates for you.
Cheers
David
Message 26 of 42
Hi David,
Jumped? from 43.59 to 43.61 Mbps!
I keep getting calls from bt india about line and advised its being looked into here but they keep calling at odd timesSmiley Frustrated
Message 27 of 42
Oh its reconfigured again at 43.17!
Sage
Message 28 of 42
Ignore calls from India, just tell them the mods from the community forum are dealing with it for you.
Moderator
Moderator
Message 29 of 42
@SRT thanks for the update. @DavidM will be back in the office tomorrow, I'll let him know that you've posted.
Message 30 of 42
OK. India just sent a message to say I should all be good blah bla and I am now DISCONNECTED😡
Would someone tell em that mods are involved as the last person I spoke to from India said ok🙄 Thank you.
