Message 11 of 16
Re: Digital Voice "free" phone?
I've just followed the link, input my phone number twice viz 01422 NNNNNN and 01422NNNNNN and I got this error message both times:
Please enter a valid phone number without a country code e.g. 01XXXXXXXXX or 02XXXXXXXXX.
It IS a valid STD phone number. There ISN'T a country code!!!
More BT nonsense.
Message 12 of 16
Re: MOST URGENT. What does my BT hub look like?
did you try sending a text as suggested in the link?
if you now have FTTP you can try phoning FTTP team 08005874787
Message 13 of 16
@imjolly Thank you, thank you, thank you, thank you! And another thank you!
I was about to post a reply saying that I'd had enough, that I pay for a phone and it doesn't work. I can't plug my phone into the hub because the fitting is completely different. I was about to say that I'm switching to Sky and will stop my direct debit payments to BT, challenging BT to try to impose a ludicrous estimated charge on me for moving away mid-contract.
But I then saw your suggestion "you can try phoning FTTP team 08005874787". I rang them just now and was immediately put through to Ellie, the best advisor I have ever spoken to out of hundreds of advisors. The outcome is that next Tuesday the 19th October, I will receive two new wireless Digital phones free of charge. Yippee!!!
PS I'll probably be back next week asking advice on how to set them up!
Message 14 of 16
@Taffy078
great result
Message 15 of 16
Did you not read my post (message 8 )about the green socket with possibly a sticker over it?
Message 16 of 16
@Taffy078
This is what @licquorice  means.
Its the socket shown in green, that is where your phone should plug into, just remove any sticker. I am assuming you have the BT Smart Hub 2, otherwise nothing will work, including the free phones.
That socket is a standard phone socket, its no different to any other.
