andyjacq
Newbie
Message 1 of 5
MT Infinity Homehub 3 & Powerlines
Hi
I've just plugged my powerline's into my new homehub 3 and they're showing all green lights right until i plug the ethernet cable in, at which point the data light turns red.  Any help appreciated
Thx
4 REPLIES 4
Message 2 of 5
Re: MT Infinity Homehub 3 & Powerlines
which port on the hub have you used ?
Guru
Message 3 of 5
What type of cable are you using?
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
andyjacq
Newbie
Message 4 of 5
Hi, im using Port 1. Thx
andyjacq
Newbie
Message 5 of 5
im using a regular ethernet cable. Thx
