I'm swapping my smart hub2 out for a separate modem router setup , I've connected the MT992 up to the master socket and I have Solid DSl light but no internet light .
Is the internet light meant to be on ? If yes what is wrong .
Hi, did you ever solve this? I have the same thing.
Unfortunately not although it seems to be working my speeds are all over the place . So I still don't know if that light should be on
Just brought an mt992 modern off ebay so I can use an Asus rt-ax88u router, Internet is working fine but the Internet led is off on my modem as well, pretty sure it should be on but as everything is working great I'm not going to worry about it.
