Jason404
Message 1 of 27
MTU setting for BT Infinity
What MTU setting should I set for my router.  The Tomato firmware that I am using has 1492 as the default.
Can anybody check to see what the default is on the BT Infinity hub please?
Cheers.
Tags (2)
26 REPLIES 26
Distinguished Guru
Message 2 of 27
Re: MTU setting for BT Infinity
Have a look back a couple of threads on this site, there is one running on Infinity.
http://community.bt.com/t5/BB-in-Home/BT-INFINITY-HUB2/td-p/13699
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Jason404
Message 3 of 27
Hey thanks, but I am already part of that discussion. 😄
PheeragHfre
Recognised Expert
Message 4 of 27
Cheers.
Ideally you shouldn't have packet fragmentation whilst entering or leaving your network.
Have you tried "pinging" the router(s) & then pinging a couple of external sources to check for this?
It should give you a good idea as to what the BT Infinity Hub MTU setting is or what it will accept.
Max MTU: How do I find mine?
"I have this awful feeling someone is watching every move I make (one of my pet hates is router location tagging)." Marvin (A paranoid Android)
Jason404
Message 5 of 27
Thanks for that link - I'm learning something here.
I'm not sure whether I should change the Windows MTU setting to match the router's or not.  The default seems to be 1500.  Should I do the ping tests without touching the Windows default MTU setting?
PheeragHfre
Recognised Expert
Message 6 of 27
You may find this utility useful, the latest version appears to be compatible with all current Windows versions.
SG TCP Optimizer
(as always check the download authenticity & use at you own risk.)
Guru
Message 7 of 27
I would have thought BTs kit would support RFC4638 with baby jumbo frames to support 1500 byte MTU.
If not (which I doubt)  1492 should do it.
BT SIN 498 stipulates that the VDSL2 Active NTE supports all packet sizes ...
So I guess that a degree of "experimentation" should do no harm. (although effect will be minimal IMHO )
Although Windows default 1500 should work ok.
PheeragHfre
Recognised Expert
Message 8 of 27
It is also worth mentioning.
If you decide to optimize the PC throughput for Internet use, this is likely to degrade throughput on your local Shares/drives or multimedia devices.
IanC
Recognised Expert
Message 9 of 27
It's also worth mentioning that one needs to be careful, amongst all of this "tuning", of optimising your setup to work well with a particular site on The Internet - eg a particular speed test site.
Ordinarily I'd suggest leaving things at defaults unless there's a specific and compelling reason to change.
One such reason existed a few years ago, when it was advised to alter the MTU for BT broadband connections. This was nothing to do with packet fragmentation. Rather, BT's network at the time was assigning a low priority to packets of over a certain size (I don't recall the specifics) and reducing the MTU got around the problem while BT got around to implementing a fix. This situation hasn't existed for a long time though - in fact, it was fixed some time before I read about it...
Guru
Message 10 of 27
I think MTU tuning was fine ... in the early days of analog modems .... and differing ISP configurations, even now maybe on a long line with DMT, but I think it's fair to say the 21cn network will undoubtedly have been designed to cater for differing latency issues and data transmission across digital networks, whether they be UK based or otherwise.
I'd be very surprised if FTTC communications is not belts and braces (given that the vdsl2 modem accepts all packet sizes) and given the investment of the product and popularity of the 1500 byte packet size for transmission.
I frankly doubt whether you'd see any difference in changing it away from default .... given the speed and throughput of the product.
