Expert
Message 1 of 14
MTU used by ECI modem/HH3
For whatever reason my MTU value seems to be set at 1452 from the ECI modem/HH3, any idea why this would be the case rather than 1492?
More importantly is there any way to change this as I'm convinced this is too low and would like to try the default of 1492 for PPPoE as my downloads seem to be quite erratic?
13 REPLIES 13
Guru
Message 2 of 14
Re: MTU used by ECI modem/HH3
Source?
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Expert
Message 3 of 14
the MTU for BT router will be set automatically at 1500 on the computer side for FTTC (WAN socket I am sure you know there is software that can adjust these settings Smiley Wink
MTU adjustments where needed sometimes on the old ADSL routers, not needed for Fibre these days !
you can change the windows side of the MTU back to 1500 using this , open up the comman prompt as administrator
netsh interface ipv4 set subinterface "Local Area Connection" mtu=1500  store=persistent
Expert
Message 4 of 14
Thanks but already checked it was set at 1500 on windows, just wondering why 1452 rather than 1492 on the router side.
As for source the easiest is probably from a myspeed quality test.
Expert
Message 5 of 14
The HH3 is set by default 1500 MTU unless you hack it, you must be using some other router ?
Expert
Message 6 of 14
It is because it is a PPPoE connection where there is an 8 byte overhead for the protocol.
Guru
Message 7 of 14
He mentioned that, he believe it's set to 1452 instead of being at 1500 (1492).
Expert
Message 8 of 14
1492 is the max but anything below that should work as long as everything else downstream is configured to use the lower value.
@Storm - If win7 I wouldn't worry too much as it should autotune but no idea why 1452.
Expert
Message 9 of 14
From MySpeed quality Test:
As you can see this is reporting an MTU of 1452, the windows side as stated is 1500. I'm getting massive amounts of TCP idle time, this is actually lower than usual. Any ideas why it is not defaulted to 1492?
Guru
Message 10 of 14
Not a clue, changing the win7 MTU to match might help you a little.
You could try a hard reset, holding the reset button for 10+ seconds.
