patrickcunn
Message 1 of 5
MacBook Pro connection Problems.
Hi,
I have just got my BtHub and my MacBook Pro will not connect to the hub at all. All other wireless networks nearby are allowing me to try and enter a password yet the BThub wont, and it i literally right beside me.
My Mac asks to run diagnostics?
4 REPLIES 4
imjolly
Message 2 of 5
Re: MacBook Pro connection Problems.
which hub have you got?  HH3/4/5?
patrickcunn
Message 3 of 5
It's a BT Home Hub 4.0 Type A.
Thanks for the response
imjolly
Message 4 of 5
the have you tried splitting the 2.4 and 5g networks by giving different ssids - say add a 5 to the 5ghz ssid.  also stop smart setup and turn off automatic channel selection and gove each ssid a specific channel and either same or different passwords.  then see you your MAC can conenct any better
patrickcunn
Message 5 of 5
Upgraded my Wireless Card and that seems to have worked. Thanks for the help though.
