Message 1 of 3
Macbooks dropping BThub4 wireless connection
Hello,  I've just switched from EE to BT broadband (for the parental controls features, not cost I assure you).
All seems fine with Windows laptop and iPads, but the 3 macbooks in the house drop their connection every so often, between ten minutes and 5 seconds.  What to do?
Please, whoever responds, be very clear as I struggle with macs.
Much appreciated.
Thank you.
2 REPLIES 2
Message 2 of 3
Re: Macbooks dropping BThub4 wireless connection
Make sure you turn off "smart setup" on the Homehub.
See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
Some devices have a problem with the Homehub dual band having the same SSid (name). You should try splitting them.
See link
http://bt.custhelp.com/app/answers/detail/a_id/44798/~/i-have-problems-connecting-5ghz-and-dual-band...
Message 3 of 3
Thank you Mr Sage.
I seem to have foudn the page through your links.
We shall see, and thank you for taking the time to respond.
