JoeP
Message 11 of 17
Re: Major help needed.
Sorry this is a foreign language to me. It's a socket in the wall that's fibre. Thats wher the router is connected to
imjolly
Message 12 of 17
Or like this
JoeP
Message 13 of 17
Master socket is second one, the extension is the first.
imjolly
Message 14 of 17
Was it an engineer install?  If so is it possible the engineer swapped the sockets so the socket you are using is now actually the master socket?
JoeP
Message 15 of 17
Basically it was a sub-contractor ordered by but not bt branded.
I don't think he changed the master socket, he asked me which one i wanted the new socket in and the kitchen was more convinient. He was in and out within 15 minutes and he didn't do anything to the master socket.
imjolly
Message 16 of 17
That could be your problem. If it had been an openreach engineer then he would have swapped the sockets about
i would try try the other socket and see if connection improves
JoeP
Message 17 of 17
ok mate cheers.
