Message 1 of 29
Massive problems accessing Google websites
Sinc earlier this afternoon I have been having huge problems accessing various Google websites (Search, Youtube, Blog etc..)
Sometimes they work, and other times they time out. I ran a few traceroutes and got the following:
Tracing route to www.google.com [31.55.163.152]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms 192.168.0.1
2 6 ms 6 ms 6 ms 217.32.147.103
3 10 ms 11 ms 6 ms 217.32.147.142
4 10 ms 9 ms 10 ms 212.140.206.82
5 10 ms 10 ms 10 ms 217.41.169.217
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * ^C
Then..
3 20 ms 23 ms 22 ms 217.32.147.142
4 14 ms 22 ms 19 ms 212.140.206.90
5 12 ms 12 ms 13 ms 217.41.169.219
6 10 ms 10 ms 12 ms 217.41.169.109
7 10 ms 9 ms 10 ms 31.55.163.13
8 10 ms 10 ms 10 ms 31.55.163.185
Then..
2 6 ms 6 ms 5 ms 217.32.147.103
3 6 ms 6 ms 6 ms 217.32.147.126
4 10 ms 10 ms 10 ms 212.140.206.98
5 10 ms 10 ms 9 ms 217.41.169.219
6 10 ms 10 ms 10 ms 217.41.169.109
7 10 ms 10 ms 10 ms 31.55.163.21
8 10 ms 10 ms 11 ms 31.55.163.213
Finally..
5 10 ms 11 ms 10 ms 217.41.169.219
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * ^C
Looks like routing problems in BT's network.
Obviously this also causes loads of issues with many websites due to Analytics not loading.
28 REPLIES 28
Newbie
Message 2 of 29
Re: Massive problems accessing Google websites
Hi there,
I have the exact same problem since this morning. It makes it impossible to connect to Google, YouTube, Google Finance, Google Maps, etc.
I have filed incident reports and been on the phone for 2.5 hrs today with 3 different BT callcenters and helpdesks in the UK and India. Every BT representative has refused to escalate the problem because "if it's only Google that is affected, then it's not a BT problem."
I am based in Kingston, where are you based? (to see if it's a local problem)
Here is my example of a broken traceroute:
Tracing route to www.google.co.uk [31.55.163.152]
1 1 ms 1 ms 1 ms BTHUB4 [192.168.1.1]
2 14 ms 7 ms 11 ms 172.16.14.6
3 * 11 ms 12 ms 213.120.158.174
4 6 ms 6 ms 6 ms 213.120.158.173
5 10 ms 10 ms 10 ms 212.140.206.82
6 10 ms 11 ms 10 ms 217.41.169.201
JK
Newbie
Message 3 of 29
I have filed another incident report with BT and referred to this thread.
I have also called BT Infinity Technical Support and urged them to escalate the issue again on the basis that I'm not a crazy person for saying that BT has intermittent routing problems to Google.
They seemed to take it more seriously and will call me back later today to confirm if the problem is still happening.
Here are the phone numbers I have collected in my struggle today:
BT Infinity Tech Support (India):  08001114567
BT Tech Help (India): 08007830089
BT Customer Options (?) (UK): 0800800030
If the problem is still here tomorrow, I plan to escalate the issue to the Executive Customer Support.
Thanks,
JK
Message 4 of 29
I'm in Staines, so quite close. Could be local, I usually hit routers in Ealing.
Newbie
Message 5 of 29
It looks like a forum moderator has silently moved the thread from "BB Speed/Connection Issues" into "Other BB Queries".
I guess I will be contacting Customer Support again tomorrow.
Message 6 of 29
It quite possible a fault with one of the links going into one of the UK datacentres run by Google, which are carried by the BT 21CN network.
The IP addresses begin with 31.55.xxx.xxx and it seems to be the final hop at 217.41.169.109 or 217.41.169.219, which seems to fail.
I have asked a moderator to provide assistance. They will post an invite on this thread, giving you a link, so you can contact them.
Moderator
Moderator
Message 7 of 29
Hi MCL and jkfly
Please use the 'contact the mods' link in my forum profile under the 'about me' section to send in your details and we'll get this looked into. You can find the link by clicking on my username.
Neil
Newbie
Message 8 of 29
I don't see any "'about me' section" nor a "'contact the mods'" link, but I would like to report that I am having a similar issue, which is causing about 30% or more of the youtube videos I attempt to watch not to load. I assume this is the same fault as a bunch of people over at the youtube subreddit who are on BT are complaining about the same issue.
Newbie
Message 9 of 29
I'm having the same issues, and like fizzee i also don't see a link for 'contact the mods'.  I also can't watch YT videos, at least most of the time. It's only been like it this evening.  I also have intermittent problems loading google.  I did a tracerouter and, like the others saw a problem in the last jump.  I'm in South West London, nr Richmond.
Newbie
Message 10 of 29
Thanks, NeilO. I have sent my details using the 'contact the mods' link.
Here is the Reddit thread with many other BT customers experiencing the same problem:
http://www.reddit.com/r/youtube/comments/1m703c/major_issues_with_youtube/
