mikebh50
Message 1 of 2
Master Socket
Hi
i am having sky fibre installed on 19th sept and my question is will the BT chap move my master socket as currently everything is hard wired from the router upstairs . Now the house is not that old and has a phone point in every room apart from the toilets. But the master socket is in the dining room but when we moved in the house had 2 phone lines one of being where the router currently is. So should it not be to much of a problem to put it upstairs as this will save a lot of mucking about.
Mike
1 REPLY 1
jac_95
Guru
Guru
Message 2 of 2
Re: Master Socket
Hi mikebh50,
Unfortunatly as your not a BT Retail Customer we are unable to help you.
BT Retail ( a communication provider like sky) do not maintain your line or exchange. This is done by Openreach ( a BTplc group business). BT Retail (who runs the bt.com website and this forum) are only a communication provider and are seperate to Openreach.
Openreach maintain the lines and exchanges for all ISP/communication providers in the UK.
You may want to try http://helpforum.sky.com/
cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
