Message 11 of 39
Re: Master socket fail.
Have you tried a full factory reset
WatchdogTS
Message 12 of 39
WatchdogTS
Message 13 of 39
Yes, I managed to access it in the end, the above is the reading I get connected directly to the master socket.
Message 14 of 39
That looks fine. If you leave it like that, the speed should eventually rise to about 8640Kbs.
See Why has my speed dropped  for an explanation.
Look at my suggestions about changing the faceplate. That is your part of the circuit.
WatchdogTS
Message 15 of 39
Thanks Keith, but I disagree with the "my part of the circuit" reference. All parts of the circuit were supplied and fitted by BT.
BT upgraded me to newer technology, namely the HH3 which in theory should be a vast improvement over my old Voyager hub, which I never had a problem with in 6 years of use.
Next BT knackered my connection by over throttling it, then insisted on sending out an engineer rather than checking at their end first, who proceeded to change a perfectly good socket leaving me with a knackered one.
In short, I fail to see how I can be held responsible for faulty equipment that was installed by BT.
Message 16 of 39
That is the way it is.
Anything after the "test" socket belongs to you, including all of the extension wiring.
By all means call BT, they will send an Openreach Technician who will fit a filtered NTE, and will then charge you £99 or £130.
Changing it yourself will cost much less.
WatchdogTS
Message 17 of 39
That is one solution, pay for something BT broke! the other is to leave when my contract ends in April. 😉
Message 18 of 39
I can be no further help. I have explained the facts, its up to you what you choose to do.
By all means ask other forum members.
WatchdogTS
Message 19 of 39
That's fine Keith, thank you for your help. It is not your fault that BT are so tight fisted. The only way to send them a message they will understand is to withdraw custom on principle.
Message 20 of 39
Just bear in mind, if you move to another ISP, that uses ADSL, you are going to get exactly the same problem, as its Openreach that look after the network, and your wiring issue will still be there.
They wont fix it for free either.
My recommendation, is that you sort the problem out yourself,
