Solved! Go to Solution.
are you a BT broadband customer?
@Bsean2250 Can you see this image? ISP Test image
@Keith_Beddoe Like the test
No I'm not with BT Broadband
Nope fraid not!!
You need to contact your own ISP to get the problem solved and probably openreach engineer visit
Oh! Just realised this isn't openreach as thats what I searched for this to come up! Sorry to waste your time
Its a simple way of checking ISP. If you try it from another connection, you will not be able to see it.
