Message 1 of 5
McAfee Virus Protect - Firewall issue
I've just installed McAfee Virus Protect on my MacBook Air 2020. The app keeps asking me to turn on the firewall - even though the firewall is already turned on! Is there a solution for this problem?
Many thanks.
4 REPLIES 4
Message 2 of 5
Re: McAfee Virus Protect - Firewall issue
Yes. Uninstall McAfee. If you look through the forum you will see that there always seems to be some sort of problem with it.
Message 3 of 5
Doesn’t that leave me vulnerable though?
Message 4 of 5
Not if you install a decent anti-virus program.
There are plenty reputable free ones such as Avast, AVG etc on the market.
Message 5 of 5
Ok, I’ll take a look at them. Many thanks for your replies.
