Message 1 of 5
McAfee hanging on installation
Hi,
Since yesterday my bundled McAfee antivirus has refused to work with options to turn on the firewall and real-time monitoring not working. I am running Mac Catalina. I have tried to reinstall the package from the BT links and it all seems good until 3/4 of the way through the install and then it hangs.
Anyone got a fix for this please as its sooo annoying not having an antivirus!
TIA
Steve
4 REPLIES 4
Message 2 of 5
Re: McAfee hanging on installation
After you un-installed it did you run the McAfee removal tool then restart your device before re-installing.
See link
http://bt.custhelp.com/app/answers/detail/a_id/38369/~/how-to-remove-then-reinstall-bt-virus-protect
Message 3 of 5
Is your bundled version of McAfee "notarized"?
The linked Support Page from McAfee gives details of what this is all about......
Message 4 of 5
Fantastic gg30340, the installer had run the removal tool for me but there was no prompt to restart the device. Tried just now and bingo! There was a very helpful walkthrough to set up the final details but no real headache! Cheers 😄
Message 5 of 5
@gg30340,
Nice one. Kudos to you.
ArnieL
