Message 31 of 202
Re: Message Delivery Failure - Anyone else having problems?
The latest mail delivery failure message I have received is dated yesterday at 19:08, but it refers to a mail sent in the hours prior to @RobbieMac's update re a fix being implemented. I have yet to receive an error message for an email initially sent "post-fix", but as we don't know about what we haven't received, difficult to confirm the state of affairs; Roger's update does sow a seed of doubt...
Message 32 of 202
Hi Everyone,
We've had a further update from our email experts and they've noticed that some of you don't have an SPF record added to your domain name. This can cause issues as anti-spam filters may not treat the email as coming from a trusted source.
There is guidance on the 123-reg support site that explains how you can set this up. I hope that helps?
Neil
Message 33 of 202
Hello @NeilO, thanks for the update and will review the SPF links provided - very good of you.
The link you have provided asks; "IP addresses in CIDR format that deliver or relay mail for this domain", "Add any other server hostname that may deliver or relay mail for this domain", and "Any domains that may deliver or relay mail for this domain"
This is whole new world to me; can  you advise what the above entries in the SPF record should be to cover the outbound BT email servers? I don't want to break the facility to send email whilst trying to fix the receipt of it 😉
Ta.
Message 34 of 202
Thanks for the update.
I've just received a new delivery failure, this one dated Thursday 8:35, so after the fix it would seem.
Thanks for the SPF pointer. I've added the 123-reg mailex.mailcore.me SPF to my domain and will see what happens in the next 24/48 hrs
thanks
Message 35 of 202
All the delivery failure notifications that I have received have been after a delay of around 24 hours.  I don't know how many attempts are made at delivery and it's not so easy to detect emails that have merely been delayed.  What has become clear now is that I have lost some important emails completely, perhaps because the notification wasn't delivered.
The majority of the emails I receive are notifications from my CCTV cameras.  Interestingly, I haven't received failure notifications for any of these.
I'm also annoyed that it doesn't seem possible to disable the Junk filter.  What I have considered for years to be a solid email service is now becoming less so. Disappointed.
Message 36 of 202
Have you tried the 123 email settings as suggested in message 32?
Message 37 of 202
Ta.
Hi @jingars I'm sorry that's not something I can offer you support with. If you need help setting up the SPF record you'll need to get assistance from your domain provider 123-reg, sorry.
Neil
Message 38 of 202
@NeilO, The 123 Reg link details the settings required if you are using 123 Reg for email.
I am not using 123 Reg for email; I am using BT. I don't think it is unreasonable to ask BT the IP range and domains of their outbound BT email servers in order to comply with a fix that BT has pointed their users towards.
https://www.validity.com/how-to-build-your-spf-record-in-5-simple-steps/
Step 1: Gather IP addresses that are used to send email (for me, that's BT)
Message 39 of 202
@jingarsthe 123-reg guide says:-
Please note: If you are using 123 email, then you should use the following SPF record:
v=spf1 mx a ip4:94.136.40.163 a:mailex.mailcore.me -all
It is 123-reg's mail servers doing the forwarding, and all of the delivery reports are coming from mailex.mailcore.me, Which is 123-reg's So i've taken that as affrimitive that i'm using 123 email. I've put their SPF in my domain and will see what happens.
Message 40 of 202
@sbadger I think our posts crossed; as above I am of the view that SPF record needs to  include the BT mail servers as I send email via BT, not 123 Reg.
For me, 123 Reg acts only as a domain registrar and DNS provider.
