JHarford
Message 1 of 5
Micro disconnections + Very slow periods
I have had infinity for 3 months, the speed is okay. Usually around 67 and 20 up on speedcheck.
However, when viewing bbc iplayer or playing a game or using Adobe Connect ( conferencing software ) , I get what feels like micro disconnections, or loss of data.
Adobe connect is unusable, due to the disconnections making it so I have to be reconnected each time. Screen sharing is ultra slow.  In - game I have spikes that I assume are the same.
BBC live keeps losing connection too.
Here is data from a tracert to bbc
1 <1 ms 1 ms <1 ms BTHomeHub.home [192.168.1.254]
2 12 ms 13 ms 12 ms 217.32.140.64
3 13 ms 12 ms 12 ms 217.32.140.14
4 13 ms 13 ms 13 ms 217.41.216.210
5 13 ms 13 ms 13 ms 31.55.164.33
6 13 ms 13 ms 13 ms 31.55.164.107
7 13 ms 12 ms 13 ms acc1-10GigE-0-2-0-6.bm.21cn-ipp.bt.net [109.159.
248.108]
8 25 ms 23 ms 23 ms core1-te0-15-0-14.ealing.ukcore.bt.net [109.159.
248.38]
9 18 ms 18 ms 18 ms acc1-10GigE-0-5-0-5.l-far.21cn-ipp.bt.net [109.1
59.254.106]
10 19 ms 18 ms 18 ms 194.74.65.42
11 * * * Request timed out.
12 21 ms 18 ms 20 ms ae1.er01.rbsov.bbc.co.uk [132.185.254.46]
13 21 ms 21 ms 21 ms 132.185.255.60
14 18 ms 18 ms 18 ms 212.58.241.131
Trace complete.
Let me know what data you'd like to see to help.
Thanks in Advance
4 REPLIES 4
Message 2 of 5
Re: Micro disconnections + Very slow periods
Are you using a wireless connection or direct Ethernet cable to your computer?
JHarford
Message 3 of 5
Hi Keith ,
Direct Ethernet cable.
Message 4 of 5
there is nothing obviously wrong with the trace route
Message 5 of 5
@JHarford wrote:
Hi Keith ,
It could be the home hub renewing the DHCP lease, it does that very often for no reason.
Try setting a static IP on your PC, using my guide here Using static IP addresses on your home network
