gw12345
Message 1 of 9
Migrating from IDNET, new to FTTC
Hi there, first post, I'm coming from idnet where i have been very happy on lastly a LLU line. I have been getting speeds on adsl for up to about 7 Mbps
My estimate is 27 Mbps, which is the lowest that anyone seems to get, is there any way I can find out which cabinet I am connected to?
Thanks in advance
8 REPLIES 8
Guru
Message 2 of 9
Re: Migrating from IDNET, new to FTTC
Hi and welcome to the forum, pop in your postcode here and it should tell you http://fttc-check.alc.im/ , since your estimate is 27MB it would seem like your are quite far from the cabinet.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
gw12345
Message 3 of 9
Whooa, that's really helpful, I've never seen that cabinet, but it's only 2 minutes walk away!
I'll check it out tomorrow.
I would have hope I may get a better speed than 27, we shall see in 3w!
Guru
Message 4 of 9
The estimates are quite conservative to be fair, lots of customers have received higher download speeds.
gw12345
Message 5 of 9
Just checking does that show the cabinet location or is it just the central location of the postcode, if I zoom in on google maps it just seems to show a house not a cabinet?
gw12345
Message 6 of 9
bump
gw12345
Message 7 of 9
I've done some more digging, and that link just seems to give me datails of the cabinet, but not the location
gw12345
Message 8 of 9
bump I'm asking for the distance from the cabinet, not the number of the cabinet
Message 9 of 9
No one can tell you
