Message 1 of 4
Mikrotik Audience
Good morning all.
Has anyone dropped one of these mesh devices in place of the Smart Hub on FTTP installations? Our telephone is provided out of the back of the smart hub, so I assume I need to configure the BT router as a modem only before I install the Audience.
Cheers
3 REPLIES 3
Message 2 of 4
Re: Mikrotik Audience
@rosbif35
The ONT is the modem not the Smart Hub, and if you use a different router, then you will lose your phone service.
Message 3 of 4
Thank you Keith for the quick reply, I had feared that was the case.
Message 4 of 4
You can of course use a mesh system that can operate in access point mode, like the Tenda Nova MW3 or similar. What you are suggesting may have that option, many mesh systems do.
