Newbie
Message 1 of 2
Missing link
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: Missing link
The cheaper option would be to disconnect the wire on terminal 3 on the socket front plate. does the same as the accelerator.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
