silverblack
Message 1 of 5
Mobile Data Add On
I was about to buy a 500mb data add on as im going to Bulgaria next week.
But i noticed it said it can only be used in the UK.Is there no add on i can buy that can used in Bulgaria ?
4 REPLIES 4
DanielS
Moderator
Moderator
Message 2 of 5
Re: Mobile Data Add On
Hi @silverblack,
Take a look at the following page:
What are BT Mobile UK add-ons?
"With BT Mobile UK add-ons you can buy extra data or minutes to boost your plan or allowance. If you're always going over your allowance you might be better off moving up to a larger data plan.
You can use your UK add-ons abroad in our Roam like Home destinations >
To find out more about UK add-ons or to place an order go to www.bt.com/mobile/manage-extras >"
Bulgaria is included.
DanielS
silverblack
Message 3 of 5
I was looking at this page and looked like it was UK only maybe it needs updating to reflect the roam like home status.
Cheers.
DanielS
Moderator
Moderator
Message 4 of 5
Can you send me the URL of that page @silverblack?
DanielS
silverblack
Message 5 of 5
