chrissheppy69
Message 1 of 11
Mobile devices
Hi all, since my UHD box did the last update I can not set a remote record from any of my phones or tablets. I have tried removing it from the box and then re syncing them but it still doesn't work. Anyone else having this problem or can help me out ?
Thanks, Chris.
10 REPLIES 10
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 11
Re: Mobile devices
which app are you using   Youview or BT TV  on  your phone/tablet  ?
what actally happens when you select a program to record using the app on the mobile device ?
Seamaster
Message 3 of 11
Re: Mobile devices
I've got exactly the same problem - the ability to set a remote record has vanished from both my iPad and iPhone. I've tried repairing both, no joy. BT TV app, latest version.
There's an even more fundamental problem - searching is broken. For example, if I search for a programme in the app I know is showing that I want to record, I get no results. But it's there; I can find it in the grid view. Even then, no option to remote record.
Seamaster
Message 4 of 11
Re: Mobile devices
PS: Just re-installed YouView app. That's working fine for both search and remote record.
Seamaster
Message 5 of 11
Re: Mobile devices
PPS: Only affecting certain channels, eg TalkingPicturesTV.
zulu17
Distinguished Guru
Distinguished Guru
Message 6 of 11
Re: Mobile devices
@Seamaster  Thanks for raising ...    can you expand upon the list of channels that you are experiencing the problem with .. ie any others than Talking Pictures.
my impression is that there look like there are issues with  Talking Pictures and True Christmas with setting recordings via the schedule in the BT TV app .
Seamaster
Message 7 of 11
Re: Mobile devices
I'm not in a position to check every single channel for you, but I note another thread drawing attention to new-to-Freeview channel PBS America is similarly knobbled:
https://community.bt.com/t5/YouView-Boxes/Cannot-remote-record-PBS-America/td-p/1802170
RobbieMac
Moderator
Moderator
Message 8 of 11
Re: Mobile devices
Hi Everyone,
Thanks for raising this issue.  We have been in touch with the TV app team and have received an update.
The problem you describe is something that we are aware of.  The issue originates from our source metadata for the EPG.  This will effect a very small percentage of programmes although this does vary by channel region.  We are working on ways to improve this but at this time I don’t have a timescale to share with you.  I am sorry for any inconvenience this may cause and will let you know in the future when any further improvements are being made.
Cheers,
Robbie
Seamaster
Message 9 of 11
Re: Mobile devices
Thanks for the update, Robbie. That's not very encouraging. On the other hand, the YouView app works perfectly, so uninstalling the BT TV app and reverting to that is an effective workaround.
zulu17
Distinguished Guru
Distinguished Guru
Message 10 of 11
Re: Mobile devices
@RobbieMac  Not convinced by the explanation you have received.
From my observation  this appears to be a channel wide problem rather than one affecting a small percentage of programs.
It does seem similar to an issue that occured back the summer  with the Discover Science and Turbo channels which were added. Then the explanation  ( @SeanD  received ) was that the EPG data link had not been turned on for these new channels.
Now for example Talking Pictures  and True Christmas  although not new channerls are channels which have have changed multiplexes  in the past couple of months.
Another channel that seems to be affected is the recently added BT IPTV channel  Nick Jnr Too
