Chappers12
Message 11 of 15
Re: Mobile signal poor
Even if I'm with bt mobile
Devon_Dave
Distinguished Guru
Message 12 of 15
I believe you would only be able to get a signal box from EE if you have an account with them rather than BT mobile. Not seen anything that they will be available to BT Mobile customers (I know that BT own EE however I believe they are still running as separate companys at the moment)
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
OlsBean
Message 13 of 15
I'm in the same situation, moved 2 of our houshold Mobiles from Vodafone to BT mobile to only find that we have no coverage from inside the house. The coverage map shows that we should have and we have never had an issue with the Vodafone signal.
I've heard that your BT mobile will work with the EE signal booster however the issue is getting the EE signal booster box activated by  EE so it can be used, as they currently will only activate for customers using EE, Orange or T-Mobile, not sure how much truth there is in this and was wondering if anyone had any first hand experience?
Devon_Dave
Distinguished Guru
Message 14 of 15
you could try getting a payg sim card on EE, obviously you would not get a decent signal. Suggest you then contact EE about registering a signal box
OlsBean
Message 15 of 15
Just for information, I now know that you need a Pay Monthly (contract) with either EE, Orange or T-Mobile in order to activate the Signal Box, a Pay As You go will not work. The signal box needs to be either new or if second hand, de-registered, this is not EE being over zealus, it's because they are strictly controlled and regulated by Ofcom in the UK.
Fortunately my step-daughter has an EE contract and as she splits her time between living with us and another address and as such she was able to activate the box.
I can confirm that once activated that it works like a dream with BT Mobile.
