Chappers12
Message 1 of 15
Mobile signal poor
Help poor signal no one at bt can help just been told will have to live with it as map says ok went to ee store to see if signal booster would work but one thing they said was bt only use 20% of EE network I have 3 sims all the family have to go round the house for some sort of signal I was with o2 for 8 years and had no problems I think I've made a big mistake
Tags (1)
14 REPLIES 14
Chappers12
Message 2 of 15
Re: Welcome to BT Mobile
pottyperson
Distinguished Guru
Distinguished Guru
Message 3 of 15
I've merged your posts because posting the same message more than once is likely to cause confusion.
mcronline
Message 4 of 15
Re: Mobile signal poor
My advice is to go into the EE store and buy the signal booster and try it. If it does not work take it back for a refund. I would also pick up a EE payg sim and check that the problem is not selective. If it is a poor signal for EE too then I would then escalate things via EE explaining the coverage checker like you did in your post. Maybe there is a fault.
Chappers12
Message 5 of 15
Thankyou but even a friend on EE has come round and still poor have spoken to bt this morning and they said a new home hub coming out some stage that will do mobile as well
Devon_Dave
Distinguished Guru
Message 6 of 15
if you can get a signal box off them it will plug into you home broadband router and would give you excellent coverage at homem
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Chappers12
Message 7 of 15
Will a EE booster work ???
Devon_Dave
Distinguished Guru
Message 8 of 15
That's the ee signal box and yes have installed one where my daughter has no signal and it works well.
Chappers12
Message 9 of 15
Do you have to phone EE to get it to work or is it a plug and play thanks for you help
Devon_Dave
Distinguished Guru
Message 10 of 15
You have to contact ee. and quote the phone number of the ee phone that is registered at the low signal address.
