General_Zod
Message 1 of 16
Modem Dropouts
Im getting 2/3 BT Infinity connection dropouts daily, the DSL light on the Openreach Modem goes and then comes back within a few minutes, some days its only once, some days 4/5 times. Ive done a quiet line test and hear not a jot so i assume its not a line, possibly a faulty modem,  i dont know, but i do know this shouldnt be happening, i was rather hoping for a rock solid connection having only switched back to BT in the last few weeks.
Any help you can give would be much appreciated as, with all due respect, ringing India seems to get you nowhere!
p.s. ive also emailed the mods about this in an attempt to get their apparently excellent help too.
15 REPLIES 15
harrjoa
Message 2 of 16
Re: Modem Dropouts
Is your Openreach FTTC modem wall mounted? If not it could be overheating which is a common problem with the boxes. If so, then phone up the helpline and tell them the modem is overheating and you need a new one. This will require an engineer to install it though.
General_Zod
Message 3 of 16
Re: Modem Dropouts
Yes it is wall mounted, i made sure the eng who came to install Infinity did just that, and its never hot to touch, at all, luke warm at most if that, which is to be expected, so i dont think its that.
harrjoa
Message 4 of 16
Re: Modem Dropouts
If you haven't already, then I would check out the diagnostic steps on the BT Help Website here http://bt.custhelp.com/app/answers/detail/a_id/13766/c/346 and then follow up by running a line test using the link provided in that article.
MrMischief
Message 5 of 16
Re: Modem Dropouts
I had the same problem after my Infinity was installed. Turns out it was the modem that was at fault. The line tested perfectly. OR engineer replaced the modem and since then no drop outs!
harrjoa
Message 6 of 16
Re: Modem Dropouts
What is the version of the modem? Anything above 3B should work fine. Anything below has the tendency to go faulty.
General_Zod
Message 7 of 16
Re: Modem Dropouts
Not sure on the version harrjoa, as i only got it installed 2/3 weeks ago im assuming it should be a newer model? Any way of finding out bar taking it off the wall to look?
Yes, thats what i am hoping MrMischief, im going to request a new modem and hope that solves the issue.
Webby
Message 8 of 16
Re: Modem Dropouts
The sticker is on the bottom so you'd have to take it off the wall. It'll be a 3B if you've just had it installed. You may as well get an engineer visit booked to look at the fault, if he suspects the modem he's replace it..if he finds a line fault he SHOULD fix it.
General_Zod
Message 9 of 16
Re: Modem Dropouts
Best way to book that eng visit Webby?
Webby
Message 10 of 16
Re: Modem Dropouts
Call the help desk and report a dropping connection fault. They'll be able to organise an engineer visit if they can see that the service is dropping and no faults are highlighted during their testing.
