Message 1 of 2
Modem and Router Switch off
Can I switch off both my Modem and Router at night, previously I was advised to keep my Router switched on 24/7 to maintain my speed, is this still the case with Infinity?
1 REPLY 1
Guru
Message 2 of 2
Re: Modem and Router Switch off
The modem on Infinity holds the connection so i would personally advise you keep the modem plugged in, the router should be fine to switch off overnight.
However, there is also a power save feature on the home hub as well.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
