jamie1667
Message 1 of 3
Modem problems with bt tv
Hi, I have a problem with my modem, I have the BT provided modem with that on the R8000 router I can watch IPTV channels and I can also watch players like Netflix etc. However, when I switch the BT modem with the Netgear DM200 I can only watch IPTV Channels and I cannot access players they all get bandwidth issues but I can't see any difference in PPPoE settings in the modem. If anyone can help that would be greatly appreciated .
2 REPLIES 2
DanielS
Moderator
Moderator
Message 2 of 3
Re: Modem problems with bt tv
Hi @jamie1667,
When you're in the Netgear GUI can you go to the ADSL section and check to see if the multiplexing method is listed as LLC-Based or VC? Also, what size do you have for the MTU?
DanielS
jamie1667
Message 3 of 3
Hi Daniel multiplexing is LLC-Based and MTU is 1492
