Message 1 of 22
Modem stats
Hi all,
Is it possible to access the new infinity modem stats as I can with the home hub?
Regards,
Frogman
21 REPLIES 21
Distinguished Expert
Message 2 of 22
Re: Modem stats
only if you hack the modem
Message 3 of 22
Re: Modem stats
Thanks for a quick reply, that's pants really then isn't it?
I also presume then that the home hub will stop giving stats as  they will be on the modem?
Regards,
Frogman
Message 4 of 22
Re: Modem stats
unfortunately yes
do you have the huawei hg612?
Message 5 of 22
Re: Modem stats
It's being installed on Thursday so I'll post then and say which modem it is.
Regards,
Frogman
Message 6 of 22
Re: Modem stats
Engineer just gone, not had a chance to test it properly yet but the modem he installed is (i guess) an ECI,
this is the label on it,
infinity modem.jpgAny chance of getting stats off it without hacking?
Regards,
Frogman
Guru
Message 7 of 22
Re: Modem stats
Unfortunately not no, only to hack it. However, there are routers out there that pick up the DSL stats such as the Draytek 2750.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
Message 8 of 22
Re: Modem stats
Unfortunately there is currently no hack available for the ECI modem.
Message 9 of 22
Re: Modem stats
That's a blow, what alternatives are on the market that could replace it?
Regards,
Frogman
Message 10 of 22
Re: Modem stats
you might find a huawei hg612 on fleabay
or theres a draytek
or a fritzbox
or a cisco ect
