Oliver341
Expert
Message 1 of 6
Moderators: can you press for a broadband usage monitor?
This is a question for the moderators. You seem to be pretty good about getting stuff done at BT. Quite a common request for users on BT Total Broadband is for there to be an online broadband usage monitor in their control panel so that they can monitor their Option 1 or Option 2 usage so that they do not exceed their quota. Installing broadband usage monitors is not always feasible given the variety of devices which connect to wifi these days.
So how about it mods, can you press to get this implemented?
Oliver.
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: Moderators: can you press for a broadband usage monitor?
Hi Oliver241
Thanks for the post. I’ve seen a few requests on different threads for this so know it’s something that a lot of forum members would like. I will pass on your comments again and make sure the right people see this feedback.
Understand what you are saying about the various devices but the best advice I can give at the moment to keep track of your usage is to use a search engine to find and download an online-usage meter for each device you are using. Search for 'internet usage meter' and you may wish to try several until you find one that meets your needs.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
Oliver341
Expert
Message 3 of 6
Hi David,
Unfortunately not all devices, such as Playstations and Xboxes, can run internet usage monitors. However I'm pleased you will raise this issue again with the relevant parties and I look forward to feedback.
Oliver.
Oliver.
Distinguished Guru
Message 4 of 6
@DavidM wrote:
Hi Oliver241
Cheers
David
As BT "own" Plusnet, who have a usage monitoring system, can't that be utilised or is there any specific reasons not to use it ?
robinbredin
Message 5 of 6
Hi, I use net meter, it is a good broadband monitor.
Distinguished Guru
Message 6 of 6
I use netlimeter 2 and Networx, but as has already been mentioned, folk who use xboxs, Wiis and other "non" computer type stuff can't monitor that usage. The router can monitor stuff, but it's unreliable and can easily be reset etc.
