Touring_Dave
Message 1 of 7
Mods, please help - BT Smarttalk 'there is an unexpected error causing a problem'
I've been trying to install BT Smarttalk over a few weeks now, have tried on more than one Android device.
Installation always ends with "Unknown Problem. There's an expected error causing a problem.  Either try again, or if problems persist, please try closing and restarting the app."
I have called helpdesk, who transfer to another helpdesk who then say another helpdesk will contact me within 48hrs but nothing ever happens.
Have installed & reinstalled the app numerous times.
Have tried different BT logins.
MyBT account shows no problems under "extras", only that Smarttalk is an available extra for my account.
If a mod could get someone with technical knowledge to contact me I'd b really grateful.
6 REPLIES 6
DavidM
Moderator
Moderator
Message 2 of 7
Re: Mods, please help - BT Smarttalk 'there is an unexpected error causing a problem'
Hi @Touring_Dave and welcome.
It sounds like you've tried everything at your end to fix this so I'll be happy to lend a hand and try to sort it out. Can you please drop me over an email witnh your details? You'll get the contact the moderators link in my profile.
Cheers
David
Touring_Dave
Message 3 of 7
@JohnC2
John,
System isn't allowing me to respond to PM hence this follow-up post on forum.
Since our chat at end of last week when you advised that a 'system fault' had been flagged and that was preventing the finalisation of the installation process I've heard nothing from your BT (System / Smart Talk) colleagues.
Can you PM me with an update if one is available.
Many thanks,
Dave.
JohnC2
Moderator
Moderator
Message 4 of 7
Hi @Touring_Dave I can see they have escalated the system fault and are due to contact you in the next 48hrs.
Cheers
John
Touring_Dave
Message 5 of 7
John, many thanks for your help. Dave.
Touring_Dave
Message 6 of 7
@JohnC2
Received a phone call from SmartTalk help desk who said they had been told by more technical people that my account has been reset and that I should try process again.
SmartTalk app now installed and working on two different mobile phones.
Many thanks for all your help in getting this directed to the correct people / level.
Regards,
Dave.
JohnC2
Moderator
Moderator
Message 7 of 7
Hi @Touring_Dave Thanks for posting back and good to hear the Smart Talk team have now got you up and running.
Many Thanks
John
