Chrisseh
Message 1 of 7
More Upload Speed My Way?
Is it at all possible to ask for more upload speed, I'm currently at 0.8 and I pay exceeding amounts for my internet on unlimited. The upload is unnaceptably slow as I wish to begin streaming, I cannot even go onto tinychat/skype cam my friends, which is absolutely horrible. Thanks.
I also have previously asked for assitance with prevention against DDoS attacks, Port Forwarding ETC and the support has been horrible, which is not what I expect from a company claiming to be the fastest internet.
6 REPLIES 6
jac_95
Guru
Guru
Message 2 of 7
Re: More Upload Speed My Way?
Hi Chrisseh,
 1) please post adsl line statistics from your Homehub/router. see below for help on this.
2) Can you please run a BT speed test (including IP Profile) http://speedtest.btwholesale.com (not beta version)[Best done with a wired, Ethernet, connection] After Quick Test is done you need to click "Further Diagnostics" to get IP Profile.
ADSL Line Statistic Help:
 If you have a BT Home Hub like the one below...
 Then:
 1) Go to http://192.168.1.254 or http://bthomehub.home
 2) click Settings
 3) Click Advanced Settings
 4) Click Broadband
 5) Click Connection or sometimes called ADSL (see picture Below)
The direct Address is http://bthomehub.home/index.cgi?active_page=9116 (for bthomehub3.A firmware ending in 1.3)
or http://bthomehub.home/index.cgi?active_page=9118 (for bthomehub3.A firmware ending in 94.1.11)
You will need to copy and past all the adsl line statistics ( Including HEC, CRC and FEC errors). You may need to click " More Details"
There are more useful links on Keith's website here: If you have an ADSL connection, please select this link
Don't have a BT Homehub/Voyager?
 http://192.168.0.1 for a netgear router and look for ADSL adsl statistics with information like noise margin and line attenuation, connection speed
• http://192.168.2.1 for a belkin router and look for ADSL adsl statistics with information like noise margin and line attenuation, Data Rate
 cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
john46
Message 3 of 7
it sounds like you are on ADSL2+ the up to 20mb download service 0.8 is a fairly typical upload speed for the service unless you were to change to a fibre service(Infinity) you will not get a faster upload from BT or any other ISP
john46
Message 4 of 7
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Chrisseh
Message 5 of 7
imjolly
Message 6 of 7
Your upload sounds about normal for adsl2/2+ and is as fast you will get unless you can get fibre. You may find that up connection speed reaches 1mb
Streaming requires download speed - what is your down connection speed? Post your adsl router stats
Ectophile
Distinguished Guru
Message 7 of 7
The upload speed is as fast as you are going to get with ADSL2+.  It tops out about 1.2M for an 18M download speed, and yours is very close to that.
That's the way ADSL is set up - more bandwidth is allocated to downloading than uploading.  There's no option to change it.
