Message 1 of 6
More connection problems.....
So every few days now i have to reset my router because the speeds are unbareable then after another 3/4 days i have to reset again and again..why is this?  i have had it on 4 days now so i can get a screenshot to post...what is going on?
ADSL Line Status
Connection information
Line state:Connected
Connection time:4 days, 17:12:23
Downstream:3,488 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):6.1 dB / 14.0 dB
Line attenuation (Down/Up):58.5 dB / 31.5 dB
Output power (Down/Up):18.6 dBm / 12.9 dBm
FEC Events (Down/Up):0 / 82
CRC Events (Down/Up):55266 / 188
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):24813 / 115
Error Seconds (Local/Remote):0 / 0
5 REPLIES 5
Message 2 of 6
Re: More connection problems.....
your connection stats look ok with stable connection with few errors and a connection speed above what you would expect for your attenuation
can you run btspeedtster and when first test completes then run diagnostic test and post results
btspeedtester
Message 3 of 6
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download  Speed
 3.34 Mbps
0 Mbps4 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 3.34 Mbps
 For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
 IP Profile for your line is - 3.16 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.36 Mbps
0 Mbps0.45 Mbps
Upload speed achieved during the test was - 0.36Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.45 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results.
Message 4 of 6
also just had to restart router because i couldnt do anything!
Message 5 of 6
btspeedtster results are ok and consistent with connection speed
if you reset can you post new stats
Message 6 of 6
ADSL Line Status
Connection time:0 day, 22:43:45
Downstream:3,552 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):5.5 dB / 14.0 dB
Line attenuation (Down/Up):58.0 dB / 31.5 dB
Output power (Down/Up):18.5 dBm / 13.1 dBm
FEC Events (Down/Up):0 / 141
CRC Events (Down/Up):11194 / 98
HEC Errors (Down/Up):9825 / 70
had to reset again.....this is abysmal!
Tags (1)
