irsean
Message 1 of 22
More speed problems.
Yesterday I was getting 2.5mb/s - 0.36 mb/s which I guess is my max after the exchange update.
Also I'm really confused about speedtest.net too. It tried to find the best server based on ping and it says that I'm in Ireland (I live in Peterborough, England). It seems everytime I restart the router I'm living in a different part of the country..?
Here are my stats..
Line state:Connected
Connection time:0 days, 00:05:15
Downstream:2.563 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):8.1 dB / 13.0 dB
Line attenuation (Down/Up):60.0 dB / 31.5 dB
Output power (Down/Up):17.4 dBm / 12.5 dBm
FEC Events (Down/Up):550289 / 78
CRC Events (Down/Up):4638 / 96
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):30998 / 73
Error Seconds (Local/Remote):364 / 140
21 REPLIES 21
irsean
Message 2 of 22
Re: More speed problems.
When I look up my IP it says I live in Ireland 😕 I'm really confused about this ..
john46
Message 3 of 22
hi can you please post the full test results not the beta one from the BT Speed test speedtester.bt.com
locations will change according to where the IP address is located nothing to worry about it is nothing to do with your location
irsean
Message 4 of 22
 Download speedachieved during the test was - 0.82 Mbps
 For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
 IP Profile for your line is - 2.32 Mbps
Upload speed achieved during the test was0.35Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.45 Mbps
john46
Message 5 of 22
ok can you posts back another test around 6pm and another around 9pm  that will show if there any exchange issues
imjolly
Message 6 of 22
your download speed is low for your profile but this could be a result of the high crc/hec errors due to line noise
are you connected to the test or master socket?  do you have other sockets in other rooms?
try quiet line test  dial 17070 option 2  should hear nothing and best with corded phone  if cordless then dull hum normal
irsean
Message 7 of 22
@john, I'll see if it improves in a few hours time.
@jolly, I have no idea if it's connected to the master or test socket ;o
imjolly
Message 8 of 22
test socket.jpg  master looks like this and is first socket in your home where BT wires enter
irsean
Message 9 of 22
There's only 1 box and it's connected to the master.
imjolly
Message 10 of 22
does it look like the one in my post?  if so can you conenct to the test socket and see if that improves your connection as that is your direct link to th exchange
