john46
Message 11 of 22
Re: More speed problems.
you need to connect your hub to the test socket as shown in the picture
irsean
Message 12 of 22
yeah it's connected to the test socket now, but speedtester.bt is giving me errors.. it tests the download/upload but when it sends the data to the server or whatever it comes up with an error.
FAQ
null
You appear to have not logged on as speedtest@speedtest_domain. In order to run the next test you should login as speedtest@speedtest_domain.
Please wait while you are redirected..
john46
Message 13 of 22
just leave it for a few hours then try again
imjolly
Message 14 of 22
if you are now in the test socket can you post new router stats please
irsean
Message 15 of 22
Line state:Connected
Connection time:0 days, 00:14:34
Downstream:2.563 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):8.6 dB / 12.0 dB
Line attenuation (Down/Up):60.0 dB / 31.5 dB
Output power (Down/Up):18.0 dBm / 12.4 dBm
FEC Events (Down/Up):1108494 / 145
CRC Events (Down/Up):9291 / 149
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):47296 / 132
Error Seconds (Local/Remote):2709 / 844
imjolly
Message 16 of 22
your crc/hec errors and error seconds are high for only 14min connected suggesting line noise which will be having an adverse effect on your download speed.  did you use a new filter when you connected to the test socket?
check this post for potential noise
http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
imjolly
Message 17 of 22
did you try the quiet line test?  was it ok?
irsean
Message 18 of 22
No new filter, nope. And the router is in the hallway, so I'm not sure if there's anything interferring with it.
imjolly
Message 19 of 22
do you have a new filter you can use with quiet line test - just trying to eliminate possible noise sources
irsean
Message 20 of 22
There's no more filters and I phoned the number and I hear nothing..?
