tonirauch
Message 1 of 4
More than 7 days?
Is there a way of setting up future recordings more than 7 days ahead (other than 'record entire series'), for example if you're going on holiday for 2 or three weeks?
3 REPLIES 3
drhowells
Recognised Expert
Message 2 of 4
Re: More than 7 days?
The simple answer is no.
drhowells
Recognised Expert
Message 3 of 4
The more complicated answer is kind of 🙂
YouView have just released a mobile app, which can be used to set recordings from a mobile phone. So, this could be used to set a recording whenever you want. At the moment, there is only an iPhone (IOS) app, but they have said an Android app should be coming soon.
Other than that, there is no other way to set a recording after 7 days.
tonirauch
Message 4 of 4
Many thanks for the replies.
I'll look out for the Android app......
