imjolly
Message 11 of 17
Re: Moved 0.8 miles down the road, internet speed appalling
As john46 said the hh2 should connect just as easy as the hh4 connects unless you have changed some of the settings. If you have then reset with button on back which will take hh2 back to factory settings
pucilowski
Message 12 of 17
Except it doesn't. I have two HH2's and a BTHub4, all have been reset to factory prior to testing. The HH2's do not make a connection to broadband.
john46
Message 13 of 17
are you using a wired connection
pucilowski
Message 14 of 17
Yes I'm using a wired connection.
ADSL connection information from my BTHub4:
19:46:43, 21 Mar. ( 59.510000) DSL noise margin: 11.00 dB upstream, 9.00 dB downstream
19:46:43, 21 Mar. ( 59.420000) DSL line rate: 448 Kbps upstream, 352 Kbps downstream
imjolly
Message 15 of 17
Are you still using the test socket?
pucilowski
Message 16 of 17
I have alternated between the test socket and regular socket.
Just switched back to the regular socket:
20:55:11, 21 Mar. ( 4167.970000) DSL noise margin: 11.00 dB upstream, 8.20 dB downstream
20:55:11, 21 Mar. ( 4167.900000) DSL line rate: 448 Kbps upstream, 384 Kbps downstream
john46
Message 17 of 17
you really need to stay in the test socket constant restarts will drive your noise margin up which will reduce your connection speed
