Nickbrace23
Message 1 of 3
Moved to BT mobile and poor reception. Booster?!
Hi all,
I've just moved all broadband, TV and mobile to BT. Unfortunately the mobile signal is weak in our house. I called BT and they told me they couldn't provide a booster as they don't work if you buy broadband through BT (as opposed to EE).
No idea if the above is correct but I wondered if anyone could give me any advice?
For the record I've come from Talktalk mobile (Vodafone) and signal was OK with them.
Thanks all 🙂
Nick
2 REPLIES 2
Devon_Dave
Distinguished Guru
Message 2 of 3
Re: Moved to BT mobile and poor reception. Booster?!
Have a check out on posts on this forum for signal assist.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Dean007
Recognised Expert
Message 3 of 3
Hi Nick.
In answer to your questions, BT mobile have currently run a trial on a signal booster but it was only for a short period and for now the trial has ended. For most the signal booster which connected to the home hub worked for those with a BT or EE mobile.
Wi-fi calling is currently working its way to the network with no current release date, but should be sooner rather than later. If you have just joined BT mobile you’ll have a choice of sticking with it until they either start issuing signal assist boxes, wait until they roll out Wi-fi calling or cancel your mobile co tracts while in the cooling off period.
Either way I would call back and ask about a signal assist box so they it’s recoded in your account notes.
