Webby
Message 11 of 25
Re: Moved to Infinity2 but speeds now limited to 40000 / 9999
Looks like mods need to get involved.
davelane85
Message 12 of 25
How do we get them involved?
Webby
Message 13 of 25
Patience...
davelane85
Message 14 of 25
Ok...
bh8er
Message 15 of 25
If it helps I recently had wrangles with BT support(?) on the phone and ended up with engineers fixing a faulted line and openreach person testing line for noise/packet loss and them getting the 20mB cap lifted. I now enjoy 79mB/19mB Infinity 2. Don't take no for an answer. Best of luck
PaddyB
Moderator
Moderator
Message 16 of 25
Hi @davelane85,
 I'll be able to take a look at your connection and run a few checks on your line.
You can send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
davelane85
Message 17 of 25
Message sent
davelane85
Message 18 of 25
Mods, not sure if you did anything, but i woke today and my stats have change to this.  Upstream is now OK, but downstream still limited to 40000, maybe i just need to wait now for DLM to do its thing
davelane85
Message 19 of 25
Mods
As discussed, this is the latest speedtest results
davelane85
Message 20 of 25
Hi Mods
As discussed, the Enginer came out yesterday but things are now worse:
