Message 1 of 4
Moving BT Sport from YouView to Sky
I have been using BT Sport on my YouView box for quite some time, but would like to use it on my Sky box now instead. I tried to activate it with the viewing card number online, but always get error messages.
I do have a BT broadband connection (Infinity 150MBps) and an active Sky subscription - both at the same address.
Unfortunately whatever problem I have, the hotline can't do anything after they find out that I have an FTTH connection
3 REPLIES 3
Moderator-Retired
Message 2 of 4
Re: Moving BT Sport from YouView to Sky
Hi rombre,
Thanks for your post.
Sorry for issues you are having getting BT Sport changed over from your Youview box. Can you send me in your details using the "Contact The Mods" link found in my profile and I will be in touch.
Thanks,
OlgaC
Message 3 of 4
Thanks Olga, I sent a message.
Moderator
Moderator
Message 4 of 4
Hi Everyone,
I just wanted to let you all know we got an order in place with the BT Fibre to the Home team and rombre has confirmed his BT sport is now working on his Sky box.
Cheers
Neil
