battlezone
Message 1 of 3
Moving Broadband Talk Number to Landline
I've ordered Infinity and as a result the BBT has been switched off instantly! Even though the install date is over two week's time.
Anyway, I never use the Landline number (it's there to provide the broadband & we used to get nuisance calls) always the BBT number.
Is it possible to 'port' the BBT number to the landline number?
2 REPLIES 2
Message 2 of 3
Re: Moving Broadband Talk Number to Landline
as far as i know the BBT Talk number goes back in to the number pool again you could ask about porting it but i am not sure they will as you currently have an allocated number on the line it could be seen as a number change which is chargeable
Message 3 of 3
Do you use BBT on any other devices, eg running Softphone on a PC, or Sipdriod on an Andriod phone. If that is the case, you can have the BBT restored.
Which version of the home hub do you have at the moment. If its a version 1.0, then it can still be used as a slave to provide BBT?
