Message 1 of 5
Moving Master Socket
My master socket in located in my dining room, I want to move it to where the Bt cable enters the house, at that point is a small bt box where the  wires are joined together from there an extention cable runs 15 mts into the dining room and connects to the master socket...phew
I dont want to have to pay Bt as it will take less that 5 minutes to do this, Ive had a look inside the small box and there are just 2 wires one orange and one white
I dont know how to connect to the 2 wires to the master socket any suggestions ?
its not rocket science folks...two wires !
4 REPLIES 4
Message 2 of 5
Re: Moving Master Socket
the two wires coming out of junction box will connect to terminals A&B on the back plate of the master either way round
Message 3 of 5
They will connect to the same 2 terminals as the extension cable does now.
Message 4 of 5
Thank you Sir...appreciate your help..
Message 5 of 5
Many thanks...appreciate you help...
