Message 1 of 6
Moving and Merging Posts.
There's a prime candidate for moving and merging a post in the Lounge this morning. It should be merged with a thread elsewhere on the main topics.
Someone will do this very quickly, no doubt.
I thought I would try my first post move, but can't find the i.d. of the destination topic.
Please can someone explain?
(Header spelling is correct for this post..Smiley Indifferent)
5 REPLIES 5
stuartrogerson
Distinguished Guru
Message 2 of 6
Re: Moving and Merging Posts.
Keith ought to be able to help
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Keith_Beddoe
Message 3 of 6
I would, if things were running a bit faster. I will take a look and see if I can idenfify it.
Terget ID is 1643501
I will merge lounge post.
I use an RSS reader, so I always have a copy of the ID number, even if a thread is moved.
Keith_Beddoe
Message 4 of 6
@Ribblelancs
The destination ID is the bit shown in bold, on this example.
https://community.bt.com/t5/Connected-Devices-Other/bt-dns-issues-southwest/td-p/1643501
Its always the number after the td-p/        Its never any number which appears after that.
For example, this thread.
https://community.bt.com/t5/BT-Infinity-Speed-Connection/Neighbours-can-get-BT-infinity-I-can-t/m-p/1643912#M218008
Ignore the #M218008 as that is not a valid ID.
If you need more help, then please let me know.
JohnC2
Moderator
Moderator
Message 5 of 6
Thanks for that guys.
Cheers
John
Message 6 of 6
Thanks Keith and all.
I'll know next time. It's the only way to learn - by mistakes!
Yes it's ironic that the BT forums are sluggish at the moment. It took several refreshes to login, and to reach the pages.
BBC, as usual is normal.
Vin
