Message 11 of 14
Re: Moving fibre entry point into house
Thank you. I just tried to post a pic but the file size is too large so it’s not letting me. Sorry!
I guess as it’s been done now, is there any solution to the original question, which is can it be moved?
Message 12 of 14
Message 13 of 14
Bracket 22’s can be fixed to UPVC Fascia Boards but only if there is a wooden frame in it.
The guidance of confirming that if the EU doesn’t know, drill a test hole! Obviously said test hole can be used when fixing the Bracket.
Its not a preferred option but sometimes necessary to get the height.
That or a Bracket 32 or 44 on the side of your house.
Message 14 of 14
D’oh you are right I forgot about that.
