Meteosat
Message 1 of 23
Moving from SKY
Hi all,
Our exchange in Porthcawl (S. Wales) has just been enabled for INFINITY, together with cabinets - we're currently on SKY - has anyone done the migration? If it's to a FTTC product do we still need a MAC?
Cheers
22 REPLIES 22
Rahat786786
Message 2 of 23
Re: Moving from SKY
Yes you will require a MAC code in order to switch from Sky to BT Infinity.
Meteosat
Message 3 of 23
Re: Moving from SKY
Thanks - that's what the online chat has just said, so its confirmed.
SKY have the habit of stopping the BB connection straight away and I have a few critical things coming uo, so I wonder if anyone has followed this migration from request to INFINITY?
Cheers
Rahat786786
Message 4 of 23
Re: Moving from SKY
Not 100% certain but I am pretty sure that the downtime of broadband will be minimal as you will only disconnected on the day Infinity is installed. That is the case with most other ISPs so should also be the case with Sky.
traynor1987
Message 5 of 23
Re: Moving from SKY
I moved from SKY to BT Infinity on the 15th November and I didn't require a MAC Code! When I ordered it the woman on the phone said I didn't need one as I was getting BT Infinity and not normal ADSL Broadband so I wasn't migrating!
Went through without a problem as well,
James
Meteosat
Message 6 of 23
Re: Moving from SKY
Well that's interesting - two different opinions - ummm - does it depend who I speak to or if I did it online?
jcampy
Message 7 of 23
Re: Moving from SKY
you will only need mac code if your are currently on sky connect if your are not they you are on there llu network so no mac code can be generated
Meteosat
Message 8 of 23
Re: Moving from SKY
Can I be 100% sure of that? Don't wish to appear to doubt you, but their online chat said I would need it.
Thanks for coming in on the thread.
Distinguished Guru
Message 9 of 23
Re: Moving from SKY
If Sky have the telephone line , then you need to bring it back to BT.
The problem can start there. If Sky had the line and you were on SKY LLU, when the line comes back to BT, SKY will stop the broadband and then you might have to wait a few days for BT activation.
If it was LLU, as said I don't believe you need or use a MAC code.
toekneem
(EASBF)
Meteosat
Message 10 of 23
Re: Moving from SKY
Line is still BT, line rental is BT call package currently Anytime is BT - the only SKY part is the BB and it is LLU and has been for a couple of years.
Cheers
