Bdavidson80
Message 1 of 4
Moving to 21cn
What is the quickest way to be migrated to adsl2 on my broadband. Bt broadband availability checker now states available. Do you know who the best people to speak to are?
Cheers
Stats from hub 4
DSL noise margin: 29.00 dB upstream, 8.50 dB downstream
DSL line rate: 448 Kbps upstream, 8128 Kbps downstream
Tags (4)
3 REPLIES 3
imjolly
Message 2 of 4
Re: Moving to 21cn
if your exchange has just been upgraded to 21CN then it could take weeks/months before BT retail to roll out to it's customers on the exchnage but when it does there will be no requirement to renew your contract to get the upgrade
however if you want to try it now instead of waiting then others have had to agree a new 12 month contract before getting the upgrade.  you can try the options team and see if they can help options team 0800 800 030
if they will not/cannot help then post back and mods may be able to assist
Bdavidson80
Message 3 of 4
Re: Moving to 21cn
Appreciate the advice - now going to be rolling to 24mb/s from 12/9/13 and should get pretty close to top end.
Cheers
john46
Message 4 of 4
Re: Moving to 21cn
be aware it could take up several months after the exchange upgrade has taken place as lines are moved over in batches
