supahoopsa
Message 1 of 7
Multiple connections - slower speed?
I am already struggling with speed from my BT home hub.
I am thinking of buying my two sons a laptop each for Christmas, so my question is if all 3 of us are connected at the same time, are my speeds going to suffer even more?
6 REPLIES 6
Message 2 of 7
Re: Multiple connections - slower speed?
your connection speed will stay the same but it will now now shared between all the devices connected
supahoopsa
Message 3 of 7
So I will see further degradation in my speed 😞
Is there any thing I can do about this?
Customer2011
Message 4 of 7
Although the actual speed of your connection won't change you will notice it is slower on each computer/laptop. This is because at the moment you get all of your internet speed going to one computer. With two laptops the speed has to be split so that all three computers have a connection. If you are already struggling for speed my suggestion would be to look at upgrading, but check with BT to see what speed your line can take, if you're already at the maximum speed then you won't get it any faster than the phoneline can handle 🙂
Message 5 of 7
Hi Welcome to the forums
If you post the full stats from your router
For homehub – type 192.168.1.254 into your browser
Navigate to ADSL Settings or use the A-Z at the top right of the home page and scroll down to ADSL Settings and click on it
Click on More Details and then post the full results.
also post the full results from http://speedtester.bt.com/
Then someone here will be able to give you a better idea of the speed available on your line
supahoopsa
Message 6 of 7
Thanks, I will try this when I get home tonight as well as all the other great advice I have found on this forum
Message 7 of 7
Glad to help anytime
